model: Asus ExpertBbook Chromebook CX5403CM
CPU:Intel Core Ultra 7 155U
SuzyQable has covered the UEFI MrChromebox-2603.2 BIOS with a CCD deprotector brush. The system is running Windows 11 24H2 LTSC. The issue is that after pressing the shift key + shutdown and then restarting, the keyboard mapping becomes invalid. I’m not sure if this is due to the BIOS?
what does this mean?
Hold down the shift key and then shut down and restart the computer. The keyboard will become nonfunctional
sounds like a bug with the EC/keyboard controller. can you provide a cbmem log that shows the EC version?
The issue you mentioned is too deep-seated. I really don’t know how to extract device logs. I’m just a computer novice. Sorry ![]()
there’s docs that tell you how
