Hi All! Got one of these as a freebie with an Asus (widows) laptop. Would love to run Win 11 on the CX3402CB if possible. From what I can gather, it’s a bit ‘too new’ “MARASOV - UERT” but if anyone has any updates, I’d love to hear about it - thanks!
AFAIK - there is No UEFI coreboot rom available for this Board yet unfortunately.
MARASOV is now supported, I have one, but I can’t figure out how to disable write protect.
Is it Ti50? Try this Disabling HWWP on Steelix and similar models - #15 by Tayne
No, It is not Ti50. “gsctool -a -I | grep AllowUnverifiedRo” had no output.
It has a Cr50, one of the commands I did showed that. “gsctool -a -I” shows that the CCD is locked. With the battery removed and from VT2 shell, “cd ~; curl -L -O mrchromebox.tech/firmware-util.sh; sudo bash firmware-util.sh” showed that only the legacy BIOS option was NOT write protected. I want to install Windows 11 and I think that requires a Full UEFI Firmware. I ordered the pieces from amazon to build myself a SuzyQ cable. I think I can then change the CCD state from ‘locked’ (closed) to ‘open’ to allow modifications. Then disable the firmware WP and enabling flashing of system firmware.
