Asus chromebox 3 gibberish terminal
I’ve removed the write protect screw and put my ASUS Chromebox 3 in developer mode, but when I press the ALT+CTR+F2 key, the terminal is filled with junk characters and I can’t enter the command correctly. I’m not sure if this is a problem with my box or if anyone else has encountered this, and if so, what is the solution.
problem with the CN65 on certain monitors it seems, I have the same issue here connected to a 34" UW
Thank you Sir, Much appreciated and you are my HERO……
