- Device: Awasuki
- OS: Zorin OS 18.1 Core
- Firmware Version: MrChromebox-2603.2
- Internal storage type:
No sound after install
Fresh install
Run audio fix script, no errors
Only dummy audio detected
Detect correct drivers and play audio
I’ve tried so many suggestions I can’t even remember. No Idea if anything made it better or worse.
lspci -v | grep Audio
00:1f.3 Multimedia audio controller: Intel Corporation Jasper Lake HD Audio (rev 01)
Subsystem: Intel Corporation Jasper Lake HD Audio
aplay -l
aplay: device_list:277: no soundcards found…
inxi -A
Audio:
Device-1: Intel Jasper Lake HD Audio driver: sof-audio-pci-intel-icl
API: ALSA v: k7.1.3-070103-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
pactl list sinks
Sink #33
State: SUSPENDED
Description: Dummy Output
Driver: PipeWire
Sample Specification: float32le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 4294967295
Mute: no
Volume: front-left: 57672 / 88% / -3.33 dB, front-right: 57672 / 88% / -3.33 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: auto_null.monitor
Latency: 0 usec, configured 0 usec
Flags: DECIBEL_VOLUME LATENCY
Properties:
node.name = “auto_null”
device.description = “Dummy Output”
audio.rate = “48000”
audio.channels = “2”
audio.position = “FL,FR”
media.class = “Audio/Sink”
factory.name = “support.null-audio-sink”
node.virtual = “true”
monitor.channel-volumes = “true”
factory.id = “18”
clock.quantum-limit = “8192”
client.id = “32”
node.driver = “true”
factory.mode = “merge”
audio.adapt.follower = “”
library.name = “audioconvert/libspa-audioconvert”
object.id = “33”
object.serial = “33”
Formats:
pcm
pactl info | grep ‘^Server Name’
Server Name: PulseAudio (on PipeWire 1.0.5)
inxi -SMA
System:
Host: asus-Awasuki Kernel: 7.1.3-070103-generic arch: x86_64 bits: 64
Desktop: GNOME v: 46.0 Distro: Zorin OS 18.1 noble
Machine:
Type: Laptop System: Google product: Awasuki v: rev3
serial:
Mobo: Google model: Awasuki v: rev3 serial:
UEFI: coreboot v: MrChromebox-2603.2 date: 05/17/2026
Audio:
amixer sset Master unmute
Simple mixer control ‘Master’,0
Capabilities: pvolume pswitch pswitch-joined
Playback channels: Front Left - Front Right
Limits: Playback 0 - 65536
Mono:
Front Left: Playback 57672 [88%] [on]
Front Right: Playback 57672 [88%] [on]
amixer sset Speaker unmute
amixer: Unable to find simple control ‘Speaker’,0amixer sset Headphone unmute
amixer: Unable to find simple control ‘Headphone’,0
