Asus C302CA cave
Ultramarine Linux recently installed and all seems to work fine, audio with the script in Documents. I just need to learn how to change screen resolution as settings in UI does not respond to change values, maybe its just i m new in Linux, keep investigating.
Any other better distro to try?
UPDATE: EndeveaurOS is faaaar better with this chromebook, now this is my first recommendaded distro. Now i’m gonna try Brunch, crossing fingers
BrunchOS
Works everything except audio, so sad
Fedora workstation Gnome wayland:
works everything but it run a bit slow. In Fedora I need to disable keyd to get touchscreen working
sudo systemctl disable keyd
rebootsudo systemctl disable keyd
reboot
