Any device booting RW_LEGACY - can I still boot when battery runs empty?
I read this yesterday but could not find the Google bug report so I can refer you to this link.
Is it true that the dev_boot_legacy flag is battery backed?
When I boot in RW_LEGACY mode, dev_boot_legacy flag is set to 1.
And when battery runs empty this flag is flipped back to 0.
Consequence is I cannot boot into my linux partition and worse not even to chromeOS complaining “missing …”. Only remedy is a usb drive recovery.
Can you confirm this known issue with RW_LEGACY booting?
Why it is important?
As older chromebooks like my Dell 7486 has less than 65% health. On multi-dat holidays if I don’t put the charger plug into the device, it is almost certain that battery will be empty after I return home.
it’s true on a lot of older devices, but I’ve not tested it recently on newer ones. YMMV.
RW_LEGACY is for dual booting Linux + ChromeOS only. If you’ve wiped ChromeOS and installed Linux while using RWL, you’re doing it wrong and taking a risk.
If you have ChromeOS installed, then you can just re-enable the crossystem flag.
thanks again @MrChromebox.
I’m considering moving earlier to UEFI boot. Screen rotation and tablet lock works.
