AMD Sensor Fusion Hub Code 10 on MARKARTH (Acer Chromebook Plus 514)
  • Device: MARKARTH
  • OS: Windows 11
  • Firmware Version: MrChromebox-2606.1
  • Internal storage type: NVMe
The “AMD Sensor Fusion Hub” device (PCI\VEN_1022&DEV_164A&SUBSYS_164A1022&REV_00) shows Code 10 in Device Manager: “This device cannot start. Not enough system resources exist to complete the API.” I’ve tried bcdedit /set firstmegabytepolicy UseAll and bcdedit /set avoidlowmemory 0x8000000 (with Secure Boot disabled to allow the second command), but the error persists unchanged after reboot. Already on the latest available firmware (2606.1).
  1. Boot Windows 11 on MARKARTH with MrChromebox-2606.1 UEFI firmware
  2. Open Device Manager > System devices > AMD Sensor Fusion Hub > Properties
  3. Observe Code 10 error under Device status
The AMD Sensor Fusion Hub should initialize normally and expose its sensors to Windows, as it does on OEM AMD laptops with native firmware.
it’s disabled on Chromebooks
