Acer Chromebox cxi4
I have an acer chromebox cxi4 computer. I want to cancel Chromeos and install Windows 10. I connected the 2 holes on the motherboard to each other. How do I know if I am a developer? Ctrl + alt + f2 does not work on the chrome installation screen. Because Linux is not seen installed in Chrome OS. Can you help me?
the directions on the chrultrabook docs and my site are very clear. The order in which to do things is explicit.
If you’re asking ā€˜how do I know if I’m in developer mode’ then you need to re-read the documentation. If you think Linux inside of ChromeOS has any relationship to any of this, then you haven’t read the documentation.
Can’t you help me a little bit, master, I connected the dots on the motherboard, I activate the developer mode, when Chromeos is opened, it says ā€œThis device is managed by TPā€¦ā€ I cannot open a terminal, so I need to install bios.
if you can’t open a terminal, then you’re not in developer mode.
If you have a managed device, none of the instructions apply
is that not clear from the documentation?
I read the documents using translation. My English is weak. Is it not possible to turn on developer mode on my device and install Windows 10? Master
not if the device is managed and developer mode is locked out.
In that case, you must flash the firmware manually using a USB programmer, treating the device as if it were bricked
Are you talking about removing and programming the eeprom on the motherboard with an eprom programmer?
no, I’m talking about flashing the chip in-place using a chip-clip as per the documentation (assuming the device has a clippable chip)
Ok, I have that file, where can I find it to program?
I don’t understand your question
USB I have the programmer. Where can I find the file that I will upload to the eprom?
the unbricking documentation on my site tells you how to get the file
Can I install Eprom on Windows 10?
you can flash the firmware image using software under Windows, however I do not recommend this:
  • you need linux to run the tools to extract parts of the stock firmware and inject them into the UEFI firmware before flashing
  • you really should only be flashing the ā€˜bios’ region of the chip, and not the entire thing
the instructions on my site tell you how to do this from Linux. I recommend using them. If you don’t, then I can’t help as I’m not a Windows user or dev.
I’ve never used Linux either, so I asked if I could do it from Windows.
I sometimes make a remote connection to install phone software. Can you make a remote connection to help me? You have explained it in detail on your site for my Chromebox device, but I am unfamiliar with Linux and I am very confused. I would be grateful if you could do it with a remote connection if possible.
then ask questions about the parts you are confused, so we can improve the documentation
Before I start flashing the bios of my Acer Chromebox CXI4 model computer with ch341a, I would like to ask some questions that come to my mind.
1-NOTE
You don’t need to do this if flashing a stock firmware backup created by the Firmware Utility Script; that image already contains the VPD.
I want to protect vpd and hwid.
2. I don’t understand the Shellball ROM and UEFI full ROM issue. Will my machine have UEFI full ROM? I downloaded a full ROM. Should I inject the VPD and HWID into it?
The rom I downloaded: coreboot_edk2-kaisa-mrchromebox_20240914.rom
there are 3 images you can flash for any given board:
  1. a stock backup made by the script (or made manually)
  2. a shellball image extracted from a recovery USB
  3. a UEFI Full ROM image
#1 has the VPD/HWID in it, #2/#3 do not, so for those you need to persist the VPD/HWID as per the instructions.
When I want to flash the coreboot_edk2-kaisa-mrchromebox_20240914.rom file
Reading ich desctriptor… done.
Couldn’t oarse the desctriptor!
I’m getting error.
