Acer Chromebox CXI4 Slow boot issue
Hi,
My acer cxi4 has a 128gb eMMC(soldered to motherboard). After I installed Windows 10, it takes 1 minute before you see mrchromebox’s logo(the rabbit) then continue to windows desktop. Anyone knows a solution to this?
emmc is much slower than sata or nvme disk. your cpu is also not the fastest.
what I can think of is try if you can expand internally with an m.2 nvme or sata, or externally thru a usb3 drive. check your bios/firmware that these expansion drives can be used as bootable drives.
the OP’s storage media is not the issue, a Baytrail Chromebook with eMMC from 2014 boots in <1s.
The issue is most likely that the device is re-running RAM training on every boot, but need cbmem logs (both timestamp and console) to see what’s actually happening
