Trackpad/touch pad driver not working
Sound driver not available
for the C720, need to select the trackpad type under UEFI platform settings. Try one, if it doesn’t work, try the other.
Audio drivers are just standard Realtek HDA, download from Realtek.
Use SDIO to install the missing PCI/system drivers.
Thanks for the feedback audio driver is already working
HOW DO I LOCATE THE UEFI PLATFORM SETTINGS?
there’s a settings menu when you press ESC at boot
Advanced Configuration → Platform Setup
Thanks for the support
Found it, it was previously on auto after interchanging there was no different
I think the issue is from motherboard chipset driver
How do I get the chipset driver of Acer Chromebook C720? I couldn’t find it in cool star
use SDIO
Using the SDI driver 1.19.4 sound driver was successful drive but the touchpad was not
While the chipset driver only need to be updated
Pls I need a working support for my Acer Chromebook C720 trackpad to work perfectly
coolstars instructions for peppy links to realteks site for the audio drivers, why aren’t you using those?
Couldn’t find chipset driver and sound driver of Chromebook Acer C720 on Cool Star and the touchpad driver available on cool Star is not working hopefully because the chipset driver aren’t installed
sounds like you need to figure out how to use Device Manager to identify devices missing drivers then, or use a different tool.
I will be grateful if you can help on details information on how to use device manger to find missing drivers ..
I’m not a Windows user/dev/, don’t provide Windows support. Plenty of YT videos explaining Windows basics.
