I installed LMDE on my device and ran the audioscript provided, restarted my device and my internal speakers are still not detected, It still says dummy output, Does anybody else know how to fix this?
I’m not seeing the debugging info needed / requested on WTT’s github page for the script
here is my system info
System:
Kernel: 6.6.74-chrultrabook arch: x86_64 bits: 64 compiler: gcc v: 13.3.0 Desktop: Cinnamon
v: 6.4.6 tk: GTK v: 3.24.38 wm: muffin vt: 7 dm: LightDM v: 1.26.0 Distro: LMDE 6 Faye
base: Debian 12.1 bookworm
Machine:
Type: Laptop System: Google product: Osiris v: rev3 serial: <superuser required> Chassis: type: 9
Mobo: Google model: Osiris v: rev3 serial: <superuser required> UEFI: coreboot
v: MrChromebox-2408.1 date: 09/14/2024
Battery:
ID-1: BAT0 charge: 16.8 Wh (28.0%) condition: 60.0/65.2 Wh (92.1%) volts: 11.5 min: 11.7
model: COSMX K AP22ABN type: Li-ion serial: <filter> status: charging cycles: 325
CPU:
Info: 12-core (4-mt/8-st) model: 12th Gen Intel Core i5-1240P bits: 64 type: MST AMCP
smt: enabled arch: Alder Lake rev: 3 cache: L1: 1.1 MiB L2: 9 MiB L3: 12 MiB
Speed (MHz): avg: 2721 high: 3799 min/max: 400/4400:3300 cores: 1: 3537 2: 3054 3: 3799 4: 3636
5: 3502 6: 3324 7: 3405 8: 400 9: 2970 10: 2903 11: 3125 12: 3178 13: 2895 14: 3010 15: 400
16: 400 bogomips: 67600
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
Device-1: Intel Alder Lake-P Integrated Graphics driver: i915 v: kernel arch: Gen-12.2 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46a6
class-ID: 0300
Device-2: Quanta ACER FHD User Facing type: USB driver: uvcvideo bus-ID: 3-6:2
chip-ID: 0408:4031 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.7 with: Xwayland v: 22.1.9 driver: X: loaded: modesetting
unloaded: fbdev,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3408x2130 s-dpi: 144 s-size: 600x375mm (23.62x14.76") s-diag: 708mm (27.86")
Monitor-1: eDP-1 model: AU Optronics 0x38a9 res: 3408x2130 hz: 120 dpi: 252
size: 344x215mm (13.54x8.46") diag: 406mm (16") modes: 2560x1600
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel Graphics (ADL GT2) direct-render: Yes
Audio:
Device-1: Intel Alder Lake PCH-P High Definition Audio driver: sof-audio-pci-intel-tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0401
API: ALSA v: k6.6.74-chrultrabook status: kernel-api
Server-1: PipeWire v: 0.3.65 status: active with: 1: pipewire-pulse status: active
2: wireplumber status: active 3: pipewire-alsa type: plugin
Network:
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:51f0 class-ID: 0280
IF: wlp0s20f3 state: up mac: <filter>
Device-2: Realtek RTL8125 2.5GbE driver: r8169 v: kernel pcie: speed: 5 GT/s lanes: 1
port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: eno0 state: down mac: <filter>
Bluetooth:
Device-1: Intel AX211 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:3 chip-ID: 8087:0033
class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter>
Drives:
Local Storage: total: 238.47 GiB used: 25.2 GiB (10.6%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WD PC SN740 SDDQNQD-256G-1014
size: 238.47 GiB speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: 73101100 temp: 51.9 C
scheme: GPT
Partition:
ID-1: / size: 225.51 GiB used: 25.13 GiB (11.1%) fs: ext4 dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 285.4 MiB used: 5.8 MiB (2.0%) fs: vfat dev: /dev/nvme0n1p1
Swap:
ID-1: swap-1 type: partition size: 8.01 GiB used: 67.2 MiB (0.8%) priority: -2
dev: /dev/nvme0n1p2
USB:
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0 speed: 480 Mb/s
chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 2-0:1 info: Super-speed hub ports: 3 rev: 3.1 speed: 20 Gb/s chip-ID: 1d6b:0003
class-ID: 0900
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0 speed: 480 Mb/s
Device-1: 3-6:2 info: Quanta ACER FHD User Facing type: Video driver: uvcvideo interfaces: 3
rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0408:4031 class-ID: fe01 serial: <filter>
Device-2: 3-10:3 info: Intel AX211 Bluetooth type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003
class-ID: 0900
Sensors:
System Temperatures: cpu: 57.0 C mobo: N/A
Fan Speeds (RPM): N/A
Repos:
Packages: 2392 pm: dpkg pkgs: 2379 pm: flatpak pkgs: 13
No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
1: deb http: //packages.linuxmint.com faye main upstream import backport
2: deb https: //deb.debian.org/debian bookworm main contrib non-free non-free-firmware
3: deb https: //deb.debian.org/debian bookworm-updates main contrib non-free non-free-firmware
4: deb http: //security.debian.org bookworm-security main contrib non-free non-free-firmware
5: deb https: //deb.debian.org/debian bookworm-backports main contrib non-free non-free-firmware
Info:
Processes: 354 Uptime: 9m wakeups: 34311 Memory: 7.61 GiB used: 5.11 GiB (67.2%) Init: systemd
v: 252 target: graphical (5) default: graphical Compilers: gcc: 12.2.0 alt: 12 Client: Unknown
python3.11 client inxi: 3.3.26
Huh for some reason it shows up in pulse control but doesn’t show up by default, It also shows the internal mic in pulse but not in the regular sound option input settings. When I plug in headphones or speaker through the headphone jack port it also just increases the internal sound and doesn’t go through the headphone/speaker. I will provide debug logs when I get home :))
Hey, I have this same issue with the same chromebook & on linux mint. Did you ever find a way to get the speakers working?
Yes! The script actually does work you just need to go into pulse audio and switch the audio output to the right one. It should be at the top!!
There isn’t an application named Pulse on Linux Mint, I ran several things i found online to download it until i ran this “sudo apt install pavucontrol” and that installed Pulse Audio Equalizer, but all i see for output is Dummy Audio. Also, what script are you talking about? (TYSM for responding :P!)
Wait I solved it lol. IDK if this is what you did but i installed Pulse Effects, then made my speaker default, then went into system settings and turned on overamplification because it didn’t get very loud. Thank you anyway ![]()
EDIT: I just discovered the speakers only work doing this when i have the Pulse Effects application open… ![]()
