Acer Chromebook 315 magma touchpad not working
I did install all drivers available. But touchpad seems tobe not working. I had to change to many versions of Windows 11.
Can someone help me. Thanks
known issue, PM me and I’ll give you a temp workaround. still waiting on Google to fix it
Yes good day
How can i resolved this problem, now im thinking of not buying the sound driver due to this issue.
Sorry im in my work now i leave this msg to you.
Brb.
Hey whats up
How can i resolved this issue?
Thanks
thinking of buying sound drivers now but it pain in the ass to put money on the patreon thingy.
is my reply above not clear? send me a PM and I can walk you thru the workaround
i dont know how to pm
i would love assistance because im also thinking about buying the driver but i need the touchpad to work
I also have an acer cb315 that after installing windows 10 onto the device the audio and touchpad will not function. I’ve downloaded your drivers several times and even went into the device manager to uninstall/update the drivers with no avail. I’ve tried to see a message button on this website to message mrchromebox directly but i don’t see that option. Can someone please help as this is a very frustrating issue
there is no need to PM me, just boot a Linux UBS, run the script, and choose the option to set the touchpad type from the menu. Follow the prompts, then reboot back into Windows and it will work assuming everything else is sorted there
Can you also help me too my touchpad isnt working and idk how i can send you a dm on here
please read my message above, there is nothing to DM me for.
