- Device: Acer Chromebook 11 (CB3-131) GNAWTY
- OS: openSUSE Tumbleweed
- Firmware Version: 2603.2 05/17/2016
- Internal storage type: eMMC
I have entered developer mode, disabled write protect, and flashed with MrChromebox UEFI firmware successfully. However, when I attempt to install the OS, the internal eMMC drive is not appearing as an option.
When I get to the page to partition the drive, the only drive that shows up is the USB I am running the installer from. Curiously, the Internal eMMC still shows up as a boot device in the UEFI.
I have attempted using Arch, openSUSE, Pop, Xubuntu… All have the same issue with only the USB showing up.
Create a bootable Linux USB (GPT - using Rufus; attempted both iso and dd).
Plug the USB Drive into the Chromebook.
Turn on the Chromebook, press ESC at the POST screen (when the coreboot logo appears), and select your USB to boot from.
Install OS to internal drive.
Internal eMMC shows up during OS installation.
