Hi all,
I have a pixelbook eve recently just went black screen when in use and fails to turn on.
It responds to the power/refresh button combo by flashing the power led but nothing on the screen.
I’m trying to find out if its recoverable in the least destructive way (firmware wise) what is actually failing but I’m not familiar with the output.
e.g. I was hoping that maybe the boot or power management had a failed update and could be recovered and it’s not a dead eMMC/RAM/screen etc
I’ve built a suzyq cable and I can see activity on two of the devices:
/dev/ttyUSB0
[676.886104 Committing NVMEM changes.]
[677.206356 AP off]
[677.207283 CC[2183.829727 Committing NVMEM changes.]
[2184.147830 AP off]
[2184.149269 CCD state: UARTEC USBEC]
[2185.626541 deferred_tpm_rst_isr]
[2185.627635 AP on]
[2185.628303 tpm_reset_request(0, 0)]
[2185.629158 tpm_reset_now(0)]
[2185.632549 tpm_init]
[2185.634059 tpm_manufactured: manufactured]
[2185.644397 tpm_reset_now: done]
[2185.645767 CCD state: UARTAP+TX UARTEC USBEC]
[2185.670162 PinWeaver: Loading Tree!]
[2185.685005 PinWeaver: Loaded Tree. restart_count = 5186]
board_update_fwmp_attributes: object at 0x100a not found
[2185.688072 Skipping commit]
[2185.932308 Skipping commit]
[2185.945316 Skipping commit]
[2185.965595 tpm_rst_asserted]
[2188.645679 Committing NVMEM changes.]
[2188.966526 AP off]
[2188.968029 CCD state: UARTEC USBEC]
[2189.746681 EC off]
[2189.748092 CCD state: USBEC]
[2190.010452 EC on]
[2190.011493 CCD state: UARTEC USBEC]
[2190.442012 deferred_tpm_rst_isr]
[2190.443164 AP on]
[2190.443809 tpm_reset_request(0, 0)]
[2190.444690 tpm_reset_now(0)]
[2190.448070 tpm_init]
[2190.449584 tpm_manufactured: manufactured]
[2190.459854 tpm_reset_now: done]
[2190.461231 CCD state: UARTAP+TX UARTEC USBEC]
[2190.485614 PinWeaver: Loading Tree!]
[2190.500423 PinWeaver: Loaded Tree. restart_count = 5186]
[2190.503486 Skipping commit]
[2190.747524 Skipping commit]
[2190.760482 Skipping commit]
[2190.781070 tpm_rst_asserted]
/dev/ttyUSB2 (note the non-printable characters at the beginning that come out sometimes from this one)
�5R� 00 06 08 0a 1f 20 3f 40 42 44 50 52 7f 00 1b 1c 1e 22 23 24
27 43 26 71 61 5a 5d 1b 1c 1e 21 22 23 24 27 43 26 71 5c 5a
60 5d 00 98
(S3->S0)
01 10 20 21 22 23 24 25 26 27 28 29 2a 34 92 00 02 7f 00 00
03 23 48 49 4a 4d 50 15 52 55 20 2f 4f 5f 0a 14 6f 26 7f 00
08 0a 1f 20 3f 40 42 44 50 52 7f 00 1b 1c 1e 21 22 23 24 27
43 71 61 5a 5d 1b 1c 1e 21 22 23 24 27 43 26 71 5c 61 5a 60
5d 00 98 <--new
[2026.904908 power state 1 = S5, in 0x003f]
[2026.905432 power state 5 = S5->S3, in 0x003f]
[2026.906670 chipset -> S3]
[2026.907138 power state 2 = S3, in 0x003f]
[2026.907757 power state 6 = S3->S0, in 0x003f]
[2026.924220 Lid Accel: MS Done Init type:0x0 range:2]
[2026.930776 Lid Accel ODR: 10000 - roundup 1 from config 1 [AP 0]]
[2026.931768 TCPC p1 Low Power Mode]
[2026.935817 Base Accel ODR: 400000 - roundup 0 from config 1 [AP 0]]
[2026.938464 Base Gyro: MS Done Init type:0x1 range:1000]
[2026.945835 Base Gyro ODR: 0 - roundup 0 from config 0 [AP 0]]
[2027.012486 Base Mag: MS Done Init type:0x2 range:2048]
[2027.019595 Base Mag ODR: 0 - roundup 0 from config 0 [AP 0]]
[2027.065858 Light: MS Done Init type:0x4 range:6000]
[2027.066425 Light ODR: 1000 - roundup 0 from config 1 [AP 0]]
[2027.067869 chipset -> S0]
[2027.074694 power state 3 = S0, in 0x003f]
[2027.090707 TCPC p1 Low Power Mode]
[2027.442801 power state 3 = S0, in 0x0039]
[2027.443319 power state 7 = S0->S3, in 0x0039]
[2027.444722 chipset -> S3]
[2027.445390 power state 2 = S3, in 0x0039]
[2027.445886 power state 8 = S3->S5, in 0x0039]
[2027.447100 chipset -> S5]
[2027.451362 Base Accel ODR: 400000 - roundup 0 from config 3 [AP 0]]
[2027.454415 power state 1 = S5, in 0x0039]
[2027.471354 TCPC p1 Low Power Mode]
[2027.490998 Base Accel ODR: 400000 - roundup 0 from config 3 [AP 0]]
[2027.496050 TCPC p1 Low Power Mode]
Port 80 writes:
00 08 0a 1f 20 3f 40 42 44 50 52 7f 00 1b 1c 1e 21 22 23 24
27 43 71 61 5a 5d 1b 1c 1e 21 22 23 24 27 43 26 71 5c 61 5a
60 5d 00 98
(S3->S0)
01 10 20 21 22 23 24 25 26 27 28 29 2a 34 00 02 7f 00 00 0f
03 23 48 49 4a 4d 50 15 52 20 2f 4f 5f 0a 14 6f 26 7f 00 06
43 26 71 61 5a 5d 1c 1e 21 22 23 24 27 43 26 71 5c 61 5a 60
5d 00 98 <--new
Both cycle around consistently so I’m assuming it’s boot-looping/watchdog resetting or something.
I have gained access to the battery so can pull it but haven’t yet as I didn’t want to accidentally wipe any data at this point (if it’s still there).
Is there any way to determine what’s causing the boot fail at this point (ideally without installing a lot of tools on my PC)?
Thanks!
