@ethanthesleepyone Where can I find the grandma GIF related to gallium OS?
Iām trying to get audio to work on Redrix on NixOS but only Pro Audio shows up (not āDefaultā). This is my configs: nix-info - Google Drive. Any suggestions?
Donāt do ucm like that, itās just more complicated that necessary. Refer to this for instructions on properly creating a ucm package Please package my chromebook ucm properly Ā· Issue #11006 Ā· batocera-linux/batocera.linux Ā· GitHub
So for SOF all I have to do is replace the upstream alsa-ucm-conf with upstream combined with GitHub - WeirdTreeThing/alsa-ucm-conf-cros at standalone? Iām confused because it seems like the only difference is that yours has mt8183. Are there changes to the main branch of upstream that arenāt part of NixOS packages yet?
Actually I think I was trying to compare your branch with the upstream main but your branch had re-created files so yours actually has Chromebook stuff that the GitHub comparison wasnāt showing me.
Also surprisingly on both jinlon and Redrix audio works out of the box if I select āPro Audioā instead of āOffā. There are a bunch of extra non-functioning speakers and mics but functionally I donāt notice a difference between āPro Audioā without running the audio script and āDefaultā after running the audio script.
UPDATE: There is a solution: Help with avoiding 50gb worth of rebuils - #15 by ChocolateLoverRaj - Help - NixOS Discourse. Iām going to switch to NixOS now
I know this is a year late.. but I been doing stuff lol
I havenāt been using my Chromebook for a while started back using ChromeOS.. Decided to try nixos today 12/16 and enabled pipewire etc .. and I forgot whatever else. installed pavucontrol and used pro audio.
Mic and speakers where working
I retired from Nixos since it worked.
Thanks
