Before I start, yes, I completely understand that restoring EOL devices is generally frowned upon based on the discussions I have seen here and on the Internet. However, I have an extremely niche use case and reasoning for why I still use an outdated version of chromeOS: nostalgia. I understand the security risks. That’s why I used a throwaway Google account created solely for the device. I purposely downgraded my old Samsung (XE303C-12) Chromebook to chromeOS 51 and it was a great document writer, Flash game player, media player, and it was somehow compatible with my old CF card reader for my photography, which the majority of my portable tech doesn’t support. It was very useful especially with its excellent battery life, but unfortunately, it died.
I wanted an upgrade in specs for an old chromeOS device, so I decided to go with the Chromebook Pixel 2013. Love this thing. The previous owner flashed the Full ROM / UEFI on the device along with Linux Mint, and they unfortunately lost their firmware file backup, so I tried restoring the firmware using a recovery USB with the script instead, and here’s where we get to the main issue:
- Device: Google Chromebook Pixel [2013] (Link)
- OS: Linux Mint 22.2 Xfce
- Firmware Type: Full ROM / UEFI
- Firmware Version: MrChromebox-2606.1 (07/14/2026)
- Internal storage type: eMMC
Attempting to restore to stock firmware results in a “failed to extract firmware for LINK from this ChromeOS recovery USB” error, along with the “Recovery image missing VERSION file.” error. I have tried an SD Card (16GB) and a USB stick (32GB) created with Google’s “Device Recovery Tool” and both storage devices produce the same issue.
Here’s the shellball directory contents it spat out, if it helps:
total 0
drwx- - - - - - 3 root root 80 Oct 7 23:24 . .
drwxr-xr-x 2 root root 40 Oct 7 23:24 bin
drwxr-xr-x 2 root root 40 Oct 7 23:24 lib
drwxr-xr-x 4 root root 80 Oct 7 23:24 .
Flash the newest Pixel recovery image onto a USB stick and/or a SD card at or above 16GB in capacity with the “Device Recovery Tool” on another computer
Insert the storage device into the Pixel
Run the Firmware Utility Script via curl, select ‘Restore Stock Firmware”, type y, press enter, repeat, type 2, press enter, press enter again, press the number that correlates to the recovery USB, press enter, and the error appears
It should have successfully restored the firmware, which upon reboot should bring me to the “ChromeOS is missing or damaged” screen.
I hope that despite it’s EOL status, we can get my beautiful Pixel back on stock chromeOS. Any help is appreciated. Thank you.
