Touchpad and touchscreen not working p
I recently installed win 11 on Landia, installed all the jasper laker driver for touchpad and touchscreen
None of the driver seems to work , also on the compatibility chart of cool Star website, Landia doesn’t lead you to it dedicated page for it own driver, instead I had to install lantis driver since they are both same chip set (Jasper lake)
I am having the same problem
Please test Linux.
If it works, you likely missed the dptf issues. Make sure you connect to the internet before installing any drivers.
If it does not, then they are likely damaged on the hardware level
Can you explain the dptf issues
I currently have my touchpad working
Meant dptf drivers, sorry, mistyped
