RW_Legacy freezes at ctrl+L
Installed RW_Legacy on my Voxel. Now, on the developer mode screen, when I press ctrl+L, the device freezes infinitely. The same happens if I navigate to ‘select alternative bootloader’ and then ‘tianocore’. Just freezes on the same developer mode screen.
Also, the flash drive stops glowing, in case it helps.
Booting from internal disk proceeds properly.
Maybe create a firmware bug report for MrChromebox?
