updated kernel maybe
Please bear with me here - I was initially concerned that the special kernel installed by the audio fix would get over-written by the regular kernel when apt upgrading, but that doesn’t seem to be happening. uname -a is reporting a later version than the one I reported above, so perhaps the special kernel is itself getting updated by apt? If not, how would I get the latest kernel?
Oh I forgot you were using Debian. I’ve always used distros / Chromebooks that work with the default kernel that the distro comes with.
Well, it’s built at GitHub - chrultrabook/debian-kernel: CI for building custom kernels for debian. You could try modifying it to use a newer kernel and then build it (either on ur computer or GitHub actions).
Yes, it would be a lot easier to have a distro where the default kernel worked with my Chromebook, but how would I know?
Besides just trying a lot of them…
You can use distros which update frequently (not Debian / Ubuntu). Here are ones which I know will probably have the latest kernels:
- Arch
- Fedora
- NixOS
There are probably many more that I don’t know about.
I’m terms of ease of use I’d recommend Fedora
Works for me running Debian (tigerlake & eldrid) Thanks for sharing!
Thanks for the suggestions. I tried manjaro, which seems to be working better for me than debian. It’s a learning curve since I’m so used to using Debian or Debian-derivatives on all my other systems (like I keep typing apt commands), but I’m pleased with how well it works. No need for special kernels.
I got Bluefin (Fedora 39) installed on my KANO Acer Spin using RW_LEGACY firmware and mostly working fine.
The only issues I’ve found so far are:
- Audio (The standard fix did not work because of non-writable filesystem; issue to track in bluefin repo)
- DONE usb-c (fix worked fine)
- Camera, not recognized as present
The other items I’ve tested in t2m’s worked fine. I’m dual booting and this isn’t my primary computer so no rush to fix audio/camera. May try to updating to the F40 bluefin image to see if that magically fixes any of the remaining items.
EDIT: Still not working on F40
I have NixOS on my Kano device and I’m having trouble with these 2 things:
- Auto-rotate of the screen does not work.
- I have keyd setup so that Alt + F7/F8 controls the keyboard brightness. When I hit the hotkeys Gnome shows the change but it doesn’t actually change the keyboard brightness.
Just want to confirm, were you able to get these working? What OS/version were you working with?
