Power button. Power off delay
Hello,
My Lenovo Chromebook 100e with Arch and Openbox turns off immediately even if I touch the power button accidentally. Is there a way to create a delay of 2-3 seconds to power off the laptop by the power button?
Thank you.
I think if you find a general Arch Linux answer you can use that answer. There is no special answer for Chromebooks. Feel free to Google adding a delay to shutting down when you press the power button in Arch.
While popular desktop interfaces like KDE or Cinnamon offers to choose what the power button does in the system settings (default action is to show Shut Down/Reboot/Log out menu), Openbox does not have a GUI configuration for it.
However, you can set up a power management tool Power management - Openbox
For example, if you use acpid, check out acpid - ArchWiki and Power management - ArchWiki.
However, this is really an Arch+Openbox question rather than a Chromebook issue (my chromebook with Arch+KDE does not shut down immediately after pressing the power button, it asks what to do). Please ask a question in https://unix.stackexchange.com/ or https://bbs.archlinux.org/ if you are unable to figure out from the Wiki.
I found this: You can ignore the short press of power key with linux - How to change Power button shutdown action to run a script under systemd - Unix & Linux Stack Exchange, and a long press will always shut down the computer anyway, in case of emergencies (e.g. not responding).
Thank you!
