Hello MrChromebox, Asus CX54 chromebook plus. When installing MrChromebox UEFI on Windows 11 lot ltsc system, the fan automatically turns on and the heat dissipation effect is poor. I don’t know if it’s due to the low usage of MrChromebox, or if there’s no feedback?
NO NO NO. BOARD NAME!!!
I don’t know what you’re trying to say here
“due to the low usage of MrChromebox”
“the heat dissipation effect is poor.”
Tested here, the fan does not run when booting Windows normally, only under load
Also, terrible subject. This post has nothing to do with the release.
