Seems to have largely fixed ever since i plugged a data transfer USB in but there are so few KARIS owners that ill document it
Cant upload so here is amediafire linkhttps://www.mediafire.com/file/tf4ezo4kvoqjcwj/debug-logs-Karis-2026-09-12_21h23m.tar.gz/fileSystem Details
- Device: KARIS (acer chromebook plus spin 714)
- OS: [Fedora 44
- Firmware Version:2603.3
- Internal storage type: NVMe
Im gonna paste the github issue i made here:Describe the bug
When playing any sound, there is a relatively quiet but still noticeable ringing noise coming from the speakers. Before, I never noticed it, then later when plugging it into the wall it only made ringing, and now it makes ringing even on battery. If I turn my ear away from the way I usually sit in, it’s not as obvious. When the sound is at 0% volume, it still makes ringing noise when playing audio. After not playing audio for more than a few seconds, it stops which is when I presume the soundcard goes to sleep. Sometimes, it is loud enough that the video sound can’t drown it out. I do not wanna try fixing this on my own because when I tried to get audio on Pop!_OS to function, I heard all sorts of awful sounds which led me to distrohop.
Distro name and version
Fedora 44 (COSMIC Spin) (i switched to kde later)
Boardname
KARIS
Logs
look above, also sound stopped working after running it, sound worked after a reboot
Install Fedora 44
Run the script, reboot, then manually install the topology file in place
No ringing noise
i hope i didnt annoy anyone
Also if you respond thanks for trying to help
