Help With Installation of Fedora - Chromebook 4 Bluebird
I have a Samsung Chromebook 4 that I am trying to install fedora on. So far what I’ve done is get the MrChromebox firmware installed and then using that I installed coreboot. Also ran fedora via usb, now I want to install fedora.
The issue is that I don’t have enough space on the 32 gb eMMC drive to install. I looked through the disk tools but shamefully I admit I don’t have a clue as to which files are junk (if any) and which are necessary.
Fedora website says the OS requires minimum 20gb storage. I understand this is pushing it but my only other options would be to use the USB as a storage device (which sucks because the laptop has only 1 usb port) to use a SD card as storage (not as bad but the only sd card I have on hand is inside my old nintendo DS, lol) or to find some other bare-bones OS.
Is there anything I can get rid of? Do I even have enough room on the storage device to install this OS, taking into account the firmware and coreboot?
You might be better off inserting a large capacity MicroSD card and installing it to there, then wiping the emmc.
I ran lsblk in a terminal to determine which is the MicroSD and which is the emmc.
/dev/sda was the MicroSD and the emmc came up as blk something or other if I remember correctly.
You’d want to use the dd tool in a terminal with Fedora booted to erase the emmc if you didn’t want the system always booting to it or maybe change that in the coreboot BIOS.
sudo dd if=/dev/zero of=/dev/mmcblk0 bs=128M status=progress is what I used for wiping the emmc on an HP chromebook I had recently before chrultrabook-ing it and giving it to a friend in Alaska.
Thanks for the reply. I’m confused.
Is Mrchromebox firmware and coreboot not contained on the eMMC drive? I was under the assumption that these two softwares were permanently needed in order to run any sort of other OS. If I wipe the eMMC, won’t that just brick my machine since I won’t have a functional BIOS?
Firmware is located in flash memory that is different from the normal storage. Even if you completely wipe the eMMC, that won’t delete the firmware.
You can open the disks utility in fedora and write a new partition table. Be sure it is a GPT partition table. This will delete everything off the drive.
