Hi everyone,
Nice to e-meet you all! I’m new here and hoping to get some advice. I have a Lenovo IdeaPad Flex 5i, and earlier today I tried flashing the UEFI full ROM using a SuzyQable, following the tutorial on MrChromebox. Unfortunately, I managed to brick my Chromebook in the process.
As far as I can recall, everything went according to the tutorial except for a couple of points:
- When I first ran the Firmware Utility Script, it mentioned a software write-protect (WP). I followed the script’s instructions to disable it and then restarted the laptop.
- I used a flash drive formatted as exFAT to back up the stock firmware. Later, when I tried to restore it, I found that the backup file wasn’t actually saved on the flash drive.
After the script reported a successful flash, I selected R to reboot, but the screen stayed black indefinitely. After waiting for quite a while, I concluded that my Chromebook was bricked.
Next, I followed the MrChromebox unbricking guide. Using the SuzyQable and another laptop running Linux Mint, I was able to read the corrupted ROM (“badrom”). However, when I tried to load the HWID with gbb_utility, it gave the error:
“No GBB found in bad flash.rom.”
Now I’m unsure how to proceed. My questions are:
Does this mean my VPD is corrupted, and should I avoid injecting the VPD extracted from the current on-board ROM?
If flashing a shellball ROM is my only option, is there a way to replace the MAC address—perhaps using the one I can recover from my router logs?
Any help or advice would be greatly appreciated. Thanks in advance!
