Hardware issue, on here cause I want linux
My Acer CB315-3H (BLORB) won’t turn on when the battery is unplugged, but I need the battery unplugged to turn off WP, not sure what to do. The battery indicator flashes orange and the screen goes
Off-On (black screen)-off-on (black screen then flashes Dev mode boot screen for a sec, flashing on light speeds up with it)-off and loops until I unplug it
Recovery mode gives me the “Chrome OS damaged or missing” screen and I can’t figure out how to boot from a drive
you can’t "boot from a drive’ in recovery mode, unless that drive is a ChromeOS recovery image.
If your device doesn’t boot with the battery disconnected, you can try a different/higher wattage USB-PD adapter, but if that doesn’t work than you need to use a SuzyQ cable
had the same issue btw on my HP 11 G6 EE. what I did was turn it on and then while it is plugged in disconnect the battery and flash the firmware. Worked for me
This worked!!! Thanks!!!
this is dangerous and not recommended
What do you recommend then?
to use a suzyqcable iirc
