Drivers wont work
I successfully installed windows on my chromebook and it runs without any problem however I tried to install drivers and even after installing drivers my wifi, touchpad etc. still doesnt work. Anybody know why does this happen and how to solve it?
Which drivers did you install?
What is your device?
I installed all of them, I solved the issue. I tried to install them with an ethernet connection and it worked this time. Thanks for the reply tho.
think you’re missing general Intel chipset drivers.
run through the powershell script (on Coolstar.org - for your model CB) that looks for those drivers on the Microsoft Update Catalog.
