Charging symbol, but battery discharge
I’m on Babytiger. Using a Hyperdrive 15in1 docking station. Everything works normal with the exception of charging. After installing weirdtreething kernel I get the charging symbol but the battery still discharges.
Charges normal from the factory charger.
Are you using KDE?
Yes Debian/kde
That issue has been around on KDE for a while.
I didn’t realize… should it charge if I drop to tty?
If you sleep then wake back up again, it will realize it isn’t charging anymore.
So is the solution to install a different de or start fresh with a different de
I mean, it doesn’t really matter. I just ignore it.
But it’s not charging via the docking station & it did in chrome os
That’s a hardware issue then, check if it works on other devices.
I only have this problem on chromebooks running linux. They charge fine in chrome os
Interesting.
So not a debian/kde problem?
Not entirely sure.
So Ive tried this on cave, shyvana, babytiger, & casta. Same results no matter. All charge in chrome os… none charge from usb-c docking station in any version of linux regardless of kernel or d.e. Should I just assume this is a usb-c feature that hasn’t been added?
When you say regardless of kernel or DE, have you tested rolling releases such as Arch or openSUSE Tumbleweed?
I have not. I tried fedora, debian, ubuntu.
Just installed arch with sddm and cinnamon. Now i don’t have display output or charging from/to docking station.
So if I disconnect the battery& built in laptop screen it will operate completely from the usb-c dock. Not the solution I was looking for but it’s something
