I’ve connected the chip successfully but when I run " sudo flashrom -p ch341a_spi"
It finds two flash chips “W25Q64BV/W25Q64CV/W25Q64FV” and “W25Q64JV-,Q” how should I proceed? Do I just need to look up the part to figure out which chip I have?
Just read the part number off the chip
99% of the time you can use the first option and it’s fine
sudo flashrom -p ch341a_spi -c “W25Q64BV/W25Q64CV/W25Q64FV” ...
Yeah I just decided to pick one. I picked the shorter one and it worked fine. I’ve got Debian 12 running on it now
