C302CA (CAVE) boot-loops after “successful” UEFI Full ROM flash: twin unit, safe to flash?
  • Device: CAVE (ASUS Chromebook Flip C302CA)
  • OS: ChromeOS (stock, Developer Mode)
  • Firmware Type: Stock → UEFI Full ROM (first-time flash)
  • Firmware Version: Google_Cave.7820.384.0 (stock) → MrChromebox-2606.1, flashed Oct 13, 2026
  • Internal storage type: eMMC
I removed the WP screw, and the script showed “Fw WP: Disabled.” I backed up the stock firmware to USB and flashed the UEFI Full ROM. The flash completed with success messages, with no errors or warnings.
After powering off and back on, the device boot-loops: no display, the keyboard backlight flashes repeatedly, and the LED next to the left USB-C port cycles amber, white, off. I waited several minutes. An EC reset (Refresh+Power) and a full power drain with the battery disconnected (including running on AC with the battery disconnected) didn’t change anything.
I tried to recover externally with a Raspberry Pi Pico (Libreboot pico-serprog) and a WSON8 6x5 pogo probe on the W25Q128FVPG. The wiring checks out with continuity, 3.3V holds steady, and the ground pad contacts. But flashrom never detects the chip (RDID returns 0x00).
Questions
  1. Is there a known issue with the CAVE Full ROM image (2606.1)?
  2. I have an identical second C302CA. Is it safe to flash with the current release, or should I use a specific version?
  3. Any tips for in-circuit WSON flashing on CAVE (power, probe positioning)?
  4. I’m in the US. If unbricking is something you’d do, I’d be interested.
I still have the stock firmware backup from the script.
  1. no. also, 2606.1 was not the latest on the date referenced, it would have been 2609.1
  2. The current release (2609.3) was validated on CAVE in pre-release testing. But no significant differences from 2609.1 outside of an EC firmware update to fix the keyboard backlight.
  3. I’ve personally flashed cave using a WSON pogo-pin probe - it’s just tricky to line up properly
  4. That’s listed on my website
