ASUS CM34 - No sound in Arch Linux
Hello,
Im using a ASUS Chromebook CM34 with Arch Linux using the MrChromebox.tech UEFI firmware and I am having an issue where I have no sound. Based on lshw, I see the following sound devices:
  *-multimedia:0
       description: Audio device
       product: Rembrandt Radeon High Definition Audio Controller
       vendor: Advanced Micro Devices, Inc. [AMD/ATI]
       physical id: 0.1
       bus info: pci@0000:05:00.1
       logical name: card0
       logical name: /dev/snd/controlC0
       logical name: /dev/snd/hwC0D0
       logical name: /dev/snd/pcmC0D3p
       logical name: /dev/snd/pcmC0D7p
       logical name: /dev/snd/pcmC0D8p
       logical name: /dev/snd/pcmC0D9p
       version: 00
       width: 32 bits
       clock: 33MHz
       capabilities: pm pciexpress msi bus_master cap_list
       configuration: driver=snd_hda_intel latency=0
       resources: irq:80 memory:d06c0000-d06c3fff
  *-multimedia:1
       description: Multimedia controller
       product: ACP/ACP3X/ACP6x Audio Coprocessor
       vendor: Advanced Micro Devices, Inc. [AMD]
       physical id: 0.5
       bus info: pci@0000:05:00.5
       version: 6f
       width: 32 bits
       clock: 33MHz
       configuration: driver=snd_sof_amd_rembrandt latency=0
       resources: irq:79 memory:d0680000-d06bffff
and aplay -l:
**** List of PLAYBACK Hardware Devices ****
card 0: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: Generic [HD-Audio Generic], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: Generic [HD-Audio Generic], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 0: Generic [HD-Audio Generic], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
I suspect this means that ALSA does not support my sound card. At first, I tried to install the sof-firmware and alsa-firmware patches but that did not work. After further research, I found these posts which mentions that I may need to add the device to a driver file and recompile the kernel:
I tried to follow those instructions to add the device and rebuild the kernel but that did not work. At this point, I’m open to any ideas.
Thanks in advance!
