Acer C314 Droid ( ROM )
Device:** Acer Chromebook 314 (C933) β€” board **DROID** (droid-rev5), platform **octopus**, Intel Gemini Lake
OS:** ChromeOS (Developer Mode enabled, WP disabled via battery disconnect)
Firmware Type:** Stock (attempting to install UEFI Full ROM)
Firmware Version:** stock ChromeOS firmware
Internal storage type:eMMC
**Summary of the Issue**
The mrchromebox.tech CDN is returning **HTTP 404** for all firmware files, making it impossible to download the Full ROM for board **DROID** (and likely other boards). This affects both:
- `firmware-util.sh` script (fails to download supporting files)
- Direct ROM download URLs (e.g. `coreboot_edk2-droid-mrchromebox_20260714.rom`)
- `download-fullrom.sh` helper script (also returns 404)
Do anybody have ROM for it? i want too boot tails from pendrive thats why i need it ;)! THANKS alot!
  1. there is no problem downloading from my site
  2. your reason above does not explain why you can’t use the script to flash
Sorry but i had error 404 from your site. Can you add me link thanks you alot :)!
the download script exists to resolve the link. there is no 404, I just tested it.
Worked thanks you mate :)! Topic can be closed all done again Thanks!
