2609.2 - Cave - No keyboard backlight
  • Device: Cave (Asus C302c)
  • OS: Chrome OS Flex
  • Firmware Version: 2609.2
  • Internal storage type: eMMC
Keyboard Backlight Disabled
  1. Install 2609.2 - No keyboard backlight
  2. Rollback to 2606.1 - Keyboard backlight works
  3. reinstall 2609.2 - No keyboard backlight again (also verified keyboard backlight setting in bios, default 50% and also bumped up to 100%) - No keyboard backlight
Keyboard backlight should be illuminated immedietely at power on, not needed to wait for OS to boot.
cbmem -1 log please
post log on pastebin or similar
here you go, thanks
Had to boot from LMDE USB, using the installed ChromeOS Flex, I received a “Table not found” error
everything looks good in the log:
[DEBUG] Chrome EC: Keyboard backlight detected (feature flag)
in the UEFI options, disable the ECRW option, then save/power off. do a hard reset (refres+power) and see if the backlight comes on. if so, go into options and re-enable ECRW, save and reboot. then tell me if it works or not
can also try using ectool from linux:
sudo ./ectool pwmgetkblight
or
sudo ./ectool kblight
should be a link for ectool in the chultrabook docs
Thanks…
disabling the ECRW option> save>reboot does allow the keyboard backlight to come on.
After a hard reset, and re-enabling the ECRW option> save >reboot, the keyboard backlight is off again
ok, so there’s an ecrw issue in that update.
please try this test build and LMK if it fixes the issue. unzip and flash using the custom ROM option in the script.
edit: link removed
Thank you,
I’m glad you edited your last reply with the new custom firmware, as I was researching the ectool from the previous request and it seemed a bit beyond my knowledge.
I installed the new firmware and after the initial reboot, the keyboard backlight was still off, but after a hard reset (refres+power) the keyboard backlight did come on and stay on through subsequent reboots.
Is this custom firmware the fix and I should keep it installed, or just part 1 of a potential fix and I should go back to a stable build?
just to make sure, you did re-enable ECRW the setup options?
Yes, I re-enebled ecrw
then you’re good to go. The fixed ECRW will be in the next release.
The ECRW update which added either vivalidi or charge control broke it when the builder LTO compiler optimzations.
The keyboard backlight code itself was unchanged. Two EC init hooks shared the same priority: one configures keyboard-backlight PWM, the other resets the PWM hardware. Under LTO their order is not stable, and in the new builds the reset ran second and cleared the enable bit, so the backlight never came up. Disabling ECRW avoided the buggy image and restored normal behavior.
The fixed image gives chip PWM init an explicit earlier priority so it always runs before backlight setup.
great, thank you very much
Fixed in 2609.3 release
